The weather applet on a new tab
Hi, My enquiry is about the weather applet on a New Tab, in the top right corner. It's to do with the accuracy, which is sketchy. The applet claims the temp is a toasty 17 deg, when the actual temp is probably about 12 deg. My first guess is that it's an update problem, ie it's showing the temp 6 hours ago. Anyway for whatever reason it's completely wrong, which I thought you might like to know. According to http://www.bom.gov.au/nsw/observations/sydney.shtml the app isn't far off but note the difference between actual & apparent temp.
